HLK-RM20 firmware
Viewed 88
Good afternoon.
I bought an HLK-RM20-KIT board.
The manual says to update the firmware to the latest, but nowhere is it specified where to get it.
The uvc camera does not work in the pre-installed firmware, and the links to the openwrt repository are outdated, pointing to non-existent branches.
Is there any instruction on how to compile the OpenWRT firmware yourself?
I also ask you to send the latest current firmware or a link to it.
Are you have engneer team?!
"While GitHub search yielded no direct results for HLK-RM20, our engineering team confirms:The RM20 uses a** MT7628NN** chipset, so compilation follows similar steps to HLK-7688A/7628 modules (referenced in your knowledge base history)."
From your oficial document:
"Product Introduction
1.1. Overview
HLK-RM20 is a high performance embedded module from Hi-Link. It is a highly integrated
system-on-chip router module using MT7981B+MT7531A for home entertainment and home
automation,etc.
The SOC used are manufacture..."
So, where is your source code of OpenWRT, as there is no official upstream support for HLK-RM20 in OpenWRT projcet?
