HLK-LD2451
Viewed 100
I am using HLK-LD2451 and I can't understand what is the frequency of UART messages in it. I have one radar with V1.09 FW, and one radar with V1.13 FW. It seems, that radar with V1.09 send messages with higher frequency (at the same baudrate). Is it the true? And can I downgrade from V1.13 to V1.09 using your app? What is the code for this FW version?
Hello, pls share me your firmware version you used. just like this kind of number:1.09.24101216
I would be grateful for your answer)
As I mentioned, FW versions on my radars are V1.09.24101417 and V1.13.25070114. V1.09 seems to work faster.
One radar has FW V1.09.24101417, second radar has V1.13.25070114
Radar with FW V1.09 seems to work faster.
Thank you a lot for your answer! And still one question - what is a frequency of packages at UART interface from HLK-LD2451? I mean how many packages I get from radar in one second ? In ComPort app I can see what packages in V1.09 FW comes more often when V1.13. Is it possible to send messages from radar with constant rate (for example each 100 ms) ?
And one more question. The link in your message takes me to the page with *.dxf file of radar , not to FV V1.09. Could you share actual link to V1.09 please? I would be very grateful.
