Info about HLK-LD2454 Radar Sensor
Viewed 107
I'm looking for information about the HLK-LD2454 sensor - I can't find any documntation is the HiLink website nor elswhere:
(1) Can you give a link to the datasheet? I can't find it;
(2) What connector is used for power and communication?;
(3) Is there a PC utility to visualize the radar image?;
(4) Does it work with the HlldRadarTool phone app? I don't see it listed there.
Thanks!
Hi! You can find documentation here.
https://h.hlktech.com/Mobile/download/FDetail/415.html
However, it is written only in Chinese. You can get technical details, though.
I've already tested with ESPHome's LD245X firmware and it works fine UNLESS connect to default UART 0 port.
Thanks!
Hello is there a better non AI actual answer to this question?
