LD2420 is working only in ASCII mode
Viewed 103
Hi
I had purchased a LD2420 sensor
I had connected it to ESP32 as per the sketch shown in https://github.com/cyrixninja/LD2420. But I understand that my sensor is working only in ASCII mode and not in binary mode. Because of this
the existing libraries are not able to process the data. Also I understand that the firmware running on my sensor is Version 1.0.0.
Is there a way to upgrade the firmware to the latest version so that I can use this sensor and complete my design
Another problem is when I communicate with sensor using the following sketch
#define RX_PIN 16 // LD2420 TX -> ESP32 RX
#define TX_PIN 17 // LD2420 RX -> ESP32 TX
void setup() {
Serial.begin(115200);
Serial2.begin(115200, SERIAL_8N1, RX_PIN, TX_PIN);
void loop()
if (Serial2.available())
String line = Serial2.readStringUntil('\n');
line.trim();
Serial.println(line);
I see that sensor is always showing Human presence even when no human is around. Is there a way to resolve this problem
Regards
Girish
Hello Girish, thank you for your feedback.the latest firmware is V1.6.1, which can be upgraded through the OTA serial port of the upper computer.
Could you pls send a email to me, then i will send you the newest firmware and the upgrade way.
My email: info@hlktech.com
Hi
Thanks a lot for your response.
Can you pls share the link to your GitHub where the arduino/ESP32 libraries are stored
Regards
Girish
Hello, sorry for the inconvenient, we haven't the official GitHub account for arduino/ESP32 libraries, so we can not to share this, wish you can understand.
