HLK-7628N reset firmvare install with serial port
Viewed 47
Hello everyone, after an unsuccessful firmware update, the web interface became unavailable. How can I reflash the module via the COM port?
Hello, do you want to refresh module through serial port? if you want to upgrade the firmware of the serial port, connect it to serial port 0, with a baud rate of 57600. If there are no logs, please pull down WDT_RST for about ten seconds and there will be logs.
