DC DC Isolated Converter B0505S-2WR3 Fails Repeatedly
Viewed 67
Dear Team,
I am using B0505S-2WR3 for supplying current of 18mA (10mA by Resistor & other 7-8mA as actual load) to my load at output of 5V while input (isolated) is powered by 5V LDO. The Resistor kept between Vout and output GND is 510 Ohms to always keep 9.8mA as continous discharge current. In datashheet it says we need to keep minimum discharge current of 40mA to perform reliably, does consumming less current will create condition that will result in part failure ? I am facing failure of multiple parts in my product. What can be reason ?
Hello, sorry to hear there are some issues with the module. To identify the root cause, could you please take photos of the defective modules and send them to my email: info@hlktech.com? Thank you in advance.
