LD2410C does not save baud rate
Viewed 93
I'm trying to use the LD2410C as one of two gate entry detectors at my facility as part of a security product.
The device works great except that it responds to winds that we have here in NE Arizona. I would like to be able to decrease it sensitivity during high wind conditions and increase it when the winds die down.
Eventually the device can be programmed through the serial port by an Arduino Uno which can handle the default baud rate, but I can't comunicate with it on a PC with a USB-Serial adapter to test it because of the non-standard baud rate.
I tried changing the baud rate to a compatible one using bluetooth, which I can but the LD2410C keeps chaning it back.
How do I permanently change the baud rate, like say 9600 baud, on the LD2410C.
Hello, you can directly changing the baud rate through the mobile app, which is permanent, but the app will not display it even the modification is successful.
This device seems like a great device to use in my application, but it is almost imposible to work with.
For testing purposes, I have it mounted in an outdoor location to monitor incoming traffic on an access road, along with a PIR sensor. It will eventually be controlled by an Arduino Uno, but at this time I've attempted to change it's parameters via the bluetooth with little success.
1. The online manual for this device does not match the devices firmware.
2. The Andoid app indicates there is an update to the app and claims to download it but is nowhere to be found and does not update itself.
3. The manual accessible to to Android app is nowhere close to matching the actual firmware.
4. Where mounted, the device responds to wind and I need to be able to decease it's senitivity during hose time, but given the inablity to find instructions that match the devices firmware, evey guess I tried has not worked because I don't have a clue as to how to achieve that.
It appears that you have a good product but without proper instructions, it's almost impossisible to design it in to my product.
I notice that your Android app is rated at a 2. In all my years I have never seen a hardware app rated so low, so I'm not the only one who is having dificulties.
Can you direct me to accurate information as to how to control this device with the bluetooth app?
Regards, Howard
Hello halverson,
Thank you for your email about the issue you faced.
I checked your question on our websiTe on 23 May. pls help to check the below reply:
The module(HLK-LD2410C) is used for indoor human presence detection, which would be affected by the moving things. we can fliter the moving objects in the room. but the outdoor environment is more complex, HLK-LD2410C is not suitable there.
If you want to mounted the radar in an outdoor location to monitor incoming traffic with PIR, pls help to check our vehicle detection radar module, which is more suitable for this application, pls help to check the docs of the module:
HLK-LD2451:https://drive.google.com/drive/folders/1Xl7lnvCAQHD2xjOfU_lpxdr0GGXO0-F6
HLK-LD2417: https://drive.google.com/drive/folders/1tvosra31ekb53i5Yn2mNGwPDNRV672jX
