HLK-LD6001C Change heartbeat or send packet on value change
Viewed 62
I was testing and using the ld6001c and it works pretty good.
However, I was disappointed to see that the sensor doesn't send the packet when person exits or enters, only at heartbeat. Is there some way to configure the sensor to send when the value of entry or exit changes? or maybe change heartbeat to a smaller number like 1 second?
Thank you
Hello Aalian, thank you for your feedback.
This is an entrance and exit detection module, which only sends data at fixed heartbeat intervals.
In addition: can not change heartbeat to a smaller number like 1 second, the min is 10s.
For more requirements, pls send to our email: info@hlktech.com
We will check with our engineer and update to you.
