HLK-20EMI for EN 55011 Voltage class B test
Viewed 77
Dear All
I'm using HLK 10M05 in my project, and the noise graph looks the same as the HLK-20EMI on your website. Would adding only the HLK-20EMI filter be enough to pass the EN 55011 Voltage class B test? Or should I use the version with the CY capacitor shown on your website?
Thanks
Thank you for your kindly answer.
What capacitor values should be used in the CY Capacitor Configuration shown in the documentation? Do you have any advice on this?
Thanks
Hello, this value for your reference: 2.2nF/400VAC
Hello, thank you for your reply. This design works well. I would like to know if you have a product available that combines the designs of the HLK-10M05 and HLK-20EMI and functions in the same way.
