HLK-LD6004 continuous bootloop
Viewed 59
I have 2 HLK-LD6004 which are in continuous bootloop.
How to restore or reflesh firmware?
Below you can see terminal output from device:
[JUMP CODE] Success jump to boot!
coboot***
Version: v2.0.7**************
[Boot Area] isUpdateFg = 0xaa, updateAppxFg: 0xff, loadFg: 0xff, factoryFg:0xff
[Boot Area] Checking APP1 integrity before loading...
[CODE] code Length0: dabc code Length1: dabc code exsit: 005a, code address: 00000010,CRC32] Stored: 0x00000000
NO CRC check of the bin file!
[Boot Area] APP1 integrity check passed, loading APP1.
[Boot Area] Flash read done.
[JUMP CODE] code Length0: 3034 code Length1: 3034 code exsit: 005a, code address: 00000010
boot***
Hello, pls try using 3.3V DC power supply first, if the module still in issue,pls feel free to contact us.
thanks for your reply.
I tried powering the modules with 3.30V DC from a lab power supply, but it didn't change the behavior of the HLK-LD6004. The UART output is the same.
HLK-Ellen,
please, help to recover module.
Hi,Could you please measure if there is 3.3V or what is the ripple?
