HLK-LD8001 on Arduino UNO
Viewed 27
I am working with the LD8001B radar module, and I am having difficulty obtaining valid distance data over UART.
Setup:
  • Microcontroller: Arduino Uno
  • Communication: UART (TX0/RX0)
  • Power supply: 3.3V - from arduino 5V + voltage divider with 1K, 2K resistors
  • Baud rate: 115200
  • BOOT1 (P19): GND
Observations:
  1. The module powers on and sends data over UART.
  2. I also observed boot-like messages such as:
    • "Success jump to boot"
    • "Boot Area Flash read done"
Issue:
  • I am not receiving valid measurement frames
  • I expected structured distance data, but instead I get error(?) or boot output
Additional test:
Measured Current <100mA, and which I am thinking is the main issue, since the datasheets require 1A.
Any guidance or example UART communication for arduino uno would be greatly appreciated.
Below is the code I used, found from a forum (https://forum.arduino.cc/t/how-to-hook-an-ld8001b/1296215/39).
Thank you in advance!
#include <SoftwareSerial.h>
SoftwareSerial mySerial(5, 4); // RX, TX
void setup() {
// Start the serial communication with a baud rate of 115200
Serial.begin(115200);
mySerial.begin(115200);
// Wait for the serial port to initialize
while (!Serial) {
delay(100);
// Hex string to send
String hex_to_send = "FDFCFBFA0800120000006400000004030201";
sendHexData(hex_to_send);
void loop() {
// Read and print serial data
readSerialData();
void sendHexData(String hexString) {
// Convert hex string to bytes
int hexStringLength = hexString.length();
byte hexBytes[hexStringLength / 2];
for (int i = 0; i < hexStringLength; i += 2) {
hexBytes[i / 2] = strtoul(hexString.substring(i, i + 2).c_str(), NULL, 16);
// Send bytes through software serial
mySerial.write(hexBytes, sizeof(hexBytes));
//read and print as HEX
void readSerialData() {
while (mySerial.available() > 0) {
byte b = mySerial.read();
if (b < 0x10) Serial.print("0");
Serial.print(b, HEX);
Serial.print(" ");
// Read and print data from software serial
char incomingByte = mySerial.read();
Serial.print(incomingByte);
Apparently the main issue is the power supply. Indeed 1A is needed, which cannot be provided by UNO.
So, just changed supply and everything works fine. No problem with UART, or the 115200 buad rate.
Thanks for your feedback.
