How can I use SDIO on HLK-7628N?
Viewed 58
I am currently using the HLK-7628N module and I would like to use the SDIO interface. However, I could not find clear information in the documentation about how to enable or configure SDIO.
Is it possible to use SDIO on this module? If yes, which pins should be used and are there any configuration steps required in the system (for example in OpenWrt, device tree, or pinmux settings)?
If anyone has experience using SDIO on HLK-7628N or knows how to enable it, I would really appreciate your guidance.
Thank you.
