LD8001 Testing is not responding with PC
Viewed 79
I purchase LD8001 and testing with laptop and all driver instlled and check with tool radar data anylyser but not respond many days check an problem.
i used CH340 with LD8001. can suggest solution. also diffrent pc also check but not any respond.
LD8001 power supplied is given in diffrent source or from CH340 PIN3.3V pleae specified?
The module is powered by 3.3V, and the input power supply capacity requirement is greater than 1A. Any power supply that can meet this requirement is acceptable. When connecting, you can use a multimeter to measure it.
