HLK-LD2415H, pin1 y pin2.
Viewed 61
Hi.
I've purchased an HLK-LD2415H radar and need to connect a relay to activate a photo and video camera. However, I don't understand how to do it.
The radar is working correctly. It's powered by 12V. The radar communicates correctly with the 2415H_TOOL_EN.exe program and is correctly configured using the photocoupler function.
With an oscilloscope, I can't see any signals on either pin 1 or pin 2.
Can you explain what electronic circuit I can connect to these two pins to activate the relay for my camera?
Thank you.
I've figured it out.
The connection must be made from VCC.
VCC to resistor, to optocoupler, to pin 1 or 2. Pins 1 and 2 don't provide an output. They only work if you use a resistor and optocoupler connected from VCC to pin 1 or 2.
Pin 1 PULSE (radar board is a high-level effective output signal version: high-level effective output pin)
Pin 2 AA (radar board is a low-level effective output signal version: low-level effective output pin)
The specific connection depends on the relay and camera model
