LD2413 does not respond after parameter change
Viewed 61
after sending a wrong timing with command 0x71 to LD2413, it stopped responding. Even if I remove the power supply. Now nothing is sent out from the TX line.
best regards.
Marco
Restart the module, if it is still no response, restore the factory settings.
sorry but in the documentation there is no command to reset it to factory setting,and also there is no RST line.thank you
I found the RST line on a capacitor and indeed it is resetting. I get a first reply from the chip ("In BootLoader!In APP0"), but then nothing is sent out.
<< RX: 49 6e 20 42 6f 6f 74 4c 6f 61 64 65 72 21 49 6e 20 41 50 50 30 f4 f3 f2 f1 04 00 00 00 00 00 f8 f7 f6 f5
<< RX:
<< RX:
