HLK-B40 change serial parameters
Viewed 78
Good day!
There is a way to change serial parameters of HLK-B40?
I found a possibility to change the baudrate, but there is no possibility to change, for example, the parity. As I see in the technical description of HLK-B40: data bit is 8, stop bit is 1 and parity is not specified (i think, in this case parity is "none").
Can I configure, for example, the following port parameters: 9600 baud, 8 data bits, even parity, 1 stop bit?
Thank you for your help!
AT+SERIAL and AT+SET are not listed in the description of the HLK-B40 module, and an error occurs when attempting to send these commands to the HLK-B40 module.
Is it possible to configure the module as desired, or should I contact the support team for assistance?
Hello Sergej, sorry for the inconvinence caused. yes, pls feel free to contact our international sales(info@hlktech.com), they will talk with our technical and update to you.
