hlk-7628n Factory firmware
Viewed 118
hi,
i am looking for the factory wet firmware.
uboot still booting but the wrong firmware got flashedprevious
hi,
thanks a lot for the info.
as i am using this chipset as a part of a communication tool i was wondering if any factory firmware is available?
Doe the QR code on the chip has any use ?
regards,
Lieven
we have openwrt and linux firmware,and if you want add some personal fuction,we also suply this service
the QR code is the module's MAC address
Hello Lieven,
Thanks for your patience.
Please help check the status of the LED indicator: if it flashes continuously, the module is the OPENWRT system version; otherwise, it is the transparent transmission version. All modules are pre-installed with factory firmware before shipment. Note that the OPENWRT version supports secondary development, allowing you to customize the system independently.
Regarding the QR code on the chip, it corresponds to the unique MAC address of each module.
Best regards
Hi-link Team
