HLK-RM08K reconnection issue
Viewed 76
Hi, I've used HLK-RM04 in "ETH-Serial" and "DHCP" mode before and now I've switched to RM08K. The problem is that my HLK-RM08K (firmware V3.60) does not reconnect to Ethernet after the cable is unplugged and replugged. It only reconnects after a power reset. Is there any solution?
Best regards
Hello Samir,
We apologize for the issues you're experiencing.
Could you please confirm whether you have tested the new HLK-RM08K module on our test board? This will help us verify if the module itself functions correctly on the test board.
If you haven't the testboard, and you need it, pls feel free to contact us: info@hlktech.com
B. regards
HI-link Team
Hello
Thanks a lot for your reply. I've bought three samples from different suppliers and all three's behavior were the same. Also, I have a test board for HLK-RM04 (KIT-V2.3) and i've tested with that too.
Is there any firmware update for this module?
Regards
