RM08K How to select AP in WIFI(STA) Network Mode
Viewed 46
Hi, I've used RM04 for a long time in WIFI(STA) and in list of AP availables had a dot in first colum to select it, now I've changed to RM08K and when I want to select a AP from the list there is no dot or other way to select the desired AP and go back to main page with the data fullfiled.
If I write the SSID, password and select STA EncType manually it doesn't connect.
Am I missing anything?
Regards
Hello Jesus,
Thank you for your support and patience.
Please help to confirm if there are any errors in the SSID, password, and encryption method of the WiFi, and then verify if the LED of the module has changed after submitting the configuration.
Wish this can help you.
B regards
Hi-link team
