HLK-SW16_V3.1, Wi-Fi Card replacement support request
Viewed 19
Hello everyone, I have a relay module with the code HLK-SW16_V3.1. I recently made a mistake. I briefly connected a DC 12V voltage to the module. The result was that the Wi-Fi module LEDs went out instantly. There was no burning, darkening, or smell on the main board. When I connected it again to 5V DC, the blue light on the main board blinked and there seemed to be no problem. What do you think I can do? Can I obtain a replacement Wi-Fi module? If I find one, and there seem to be sellers online, I don't know the exact product code. What is the appropriate Wi-Fi module product code? Also, if I find the same Wi-Fi module, will I need to reprogram it? Will I need to install any additional software to reactivate the relay board? Or are these boards plug-and-play? Many thanks in advance to anyone who can help me with this. Sincerely
Hello, Thank you very much for the quick reply. The HLK-RM04 module I need is sold in my country, Türkiye. However, the seller doesn't have enough information regarding whether this Wi-Fi card is an HLK-RM04 module with firmware compatible with the HLK-SW16 relay application. If this card doesn't have compatible firmware with my HLK-SW16 relay card, could you help me install the appropriate firmware? Regards
Hello, i regret to inform you that the module HLK-RM04 has been discontinued due to the chip shortage.
HLK-SW16 röle kartı üzerinde bulunan HLK RM04 wi-fi kartım arızalandı. Aynı kartın yenisini ülkemde bularak taktım. Wifi Kart ışıkları yanıyor, bağlantı modunda HLK... uzantılı wifi ağı da görünüyor. Ancak daha önceki kartımda android cep telefonunda web browsera 192.0168.16.254/p2p.asp yazarak ulaşabildiğim UUID ve şifre sayfasına erişemiyorum, browser da "site yada sayfa bulunamadı" , "URL açılamaz" hatası almaktayım. Ancak browsera yalnızca 192.168.16.254 adresi yazılıp onaylandığında bu defa 192.168.16.254/Serial2Net. adresine otomatik giderek "HLK-RM04 Serial2Net " web arayüzüne ve HLK-RM04 Serial2Net Settings başlıklı sayfaya erişebiliyorum. Ancak bu ara yüzde, Net Mode Olarak Wifi Client-Serial seçerek, kablosuz ağları taratarak ev ağımı bulup seçiyorum uygula dediğimde ev ağının adı SSID alanına yapışmıyor boş kalıyor. Buna rağmen ev ağı ad ve şifresini ilgili alanlara menuel olarak yazarak ilerlediğimde, bağlantı sağlanıyormuşçasına ilerleyen sürecin sonunda, RMO4 kart ev ağına bağlanamıyor, modem arayüzünde, bağlı cihazlar arasında bulamıyorum, kartın mac adresini. Sanırım benim SW16 kartım üzrindeki RM04 p2p Firmware sürümü idi. Yeni aldığım kart ise "Serial2Net" sürümü. Lütfen bu sorunun çözümü için bana yardımcı olabilir misiniz ? Çok zor durumda kaldım.Ne yapabilirim. Firmware değiştirmem gerekirse bu eski sürümü nereden bulup indirebilirim.Hangi adımları takip ederek karta yükleyebilirim. Yardımlar için şimdiden çok teşekkür ederim. Saygılarımla
