LD2410S Data refresh cycle
Viewed 40
I'm using the LD2410S for a battery-powered system. It's excellent and very energy-efficient. However, I need a longer data refresh cycle time, ideally up to 1800 seconds.
Is this technically possible, or do you have a different type of sensor?
Thank you.
thank you for the great, detailed answer.
I'm aware of the possibilities with an additional microcontroller like an ESP, etc., and I'm already using your LD2410S software tool. However, in my case, that would increase power consumption, as I would have to reset the update cycle after each new detection.
The alternative with an HVAC-LD2412 isn't an option for me, as its 90mA power consumption is far too high for a battery-powered device.
I would be interested in a custom solution with modified firmware, as I anticipate needing thousands of these sensors for my application.
Thank you.
