Latest firmware version for the LD2413?
Viewed 35
What is the latest firmware version for the LD2413?
I need calibrate to oil detect.
Hello, we are using the firmware version (HLK-LD2413-1.1.9)now,pls help check it.
but i using the "HLK-LD2413_TOOL" ... e try modify that parameters but when i update at "Update Threshold" ... the module not update ... -----Could you pls take a video to show the problem and send to info@hlktech.com, our team will check and update to you.
Thank you inadvance.
Hi Ellen , I checked if the firmware version is correct! I reviewed the manual and was able to change the parameters.
hmm right , but i using the "HLK-LD2413_TOOL" ... e try modify that parameters but when i update at "Update Threshold" ... the module not update ... can help me?
Have any guidance for calibrate ... for example .. detect water , oil diesel ...(because i belive there is an influence when it comes to the dielectric constant)
