HLK-LD2460 unresponsive; only sending 00 permanently on the serial port
Viewed 43
my LD2460 modul was working perfect. I played a little bit with the Radar Tool on PC. Changing the different parameters. All was working fine.
In the end I performed a factory reset to have a defined situation again.
But now the modul is unresposive with both Radar Tool on PC and IOS as well.
On the PC I see it's sending 00 permanently.
Any suggestions how to fix this?
Hello, pls refer to the above advise, if you still have issues,pls reach out to us at info@hlktech.com
Hello, thnks for your quick response.
as the LD2460 modul has no reset button, I guess the recovery mode may be a solution.
Could you please provide more specific instructions about how to work with the recovery mode?
Especially: what dooes it mean "while holding the AT command entry sequence"?
And also a list of the At commands
Thank you very much in advance.
Egbert
