LD2410 FCC Certificates
Viewed 41
I was wondering if any other products in the LD2410 series have been tested for FCC compliance besides the LD2410B. The only certificate I was able to find is 2AD56HLK-LD2410-P. Although the products may be electrically identical, the FCC is very strict about physical shape and form factor as well. I’m curious whether the same certificate can be used for the rest of the products in the series.
Thank you.
CE certified: HLK-LD2410C, HLK-LD2410, LD2410B
FCC certified: HLK-LD2410B, LD2410B-P, LD2410-P, HLK-LD2410
Pls feel free to contact us if you need the certifications,we will send to your email.
Our contact way: info@hlktech.com
